Speed 25 Front Brake cable removal... Whats the trick ?
For Speed 20, Speed 25, 3.5 Litre and Crested Eagle cars
NeilWillatt
Postby NeilWillatt » Mon Nov 20, 2017 4:43 pm
Can anybody help with advice on how to remove and replace the offside front brake cable on a Speed 25. The nearside one comes off easily, with the clevis at the rear end of the cable passing nicely through the hole in the chassis.The offside one seems impossible because it passes between two vertical tubes inside the chassis rail which support the steering box. There isn't anywhere near enough clearance to get the clevis past these tubes and they seem to be an integral part of the chassis. There must be a way but I cant work it out !
alvisvoyeur
Re: Speed 25 Front Brake cable removal... Whats the trick ?
Postby alvisvoyeur » Fri Nov 24, 2017 8:12 am
From Peter Miller the Alvis Car Club of Victoria's Speed Model Technical Officer - "Yes, completely remove the steering box securing bolt behind which the brake cable passes, and slacken the nut on the other one. This will allow the top and bottom flanges of the chassis rail to spring apart slightly and the vertical tube preventing the brake cable from being removed will then slide out. Easy!"
NeilWillatt
Postby NeilWillatt » Fri Nov 24, 2017 2:39 pm
Many Thanks Peter, I have already attempted this, but the tube didn't seem to want to move and I didn't like to resort to brute force. Now I know it is supposed to move I will be a bit more robust in my approach!
Return to “Speed Models”
