Firefly rear wheel bearings.
For Firefly and Firebird cars
FLYJCW
Name: John Whiteside
Postby FLYJCW » Wed Aug 24, 2016 10:53 pm
My Firefly rebuild of the 14th car ever made 9914 continues apace. When the chassis was finished I set about going around all four wheels and inspecting brakes and bearings. Three were OK, just needing a clean and some copperslip on the moving parts of the brakes but the nearside rear hub bearings felt loose and graunchy.
I started to dismantle it and was immediately suspicious when the 2BA retaining screw on the centre nut of the axle was positioned at the twenty two segment of the clock. I t should be situated at the top of the nut in the 12 o’clock position.
The screw came out OK but it took 3 foot Stilson wrench and all my (not inconsiderable) weight to move the nut. I patiently turned it until it was off, only to reveal that the 2BA locking screw had sheared some time previously which had allowed the hub to move. The nut had been fretted away and was scrap.
Fortunately Red Triangle have new ones so I ordered the bearings the nut and new tab washers for the five hub hold down screws……. it cost as much as the GDP of a small country, but hopefully the repair will last another 84 years!
The new axle end nut is huge and beautifully CNC machined however I did not have a spanner that was 2 1/4 across the flats or a socket, neither did any one I knew. I drew a blank on eBay too so there was nothing for it but to make one, see the pictures of the process.
Cleaning up and rebuilding is always fun and the only tricky bit is re drilling the retaining screw in the new nut and tapping it 2BA but that went like clockwork.
So next job is to dismantle and examine the clutch…… watch this space. JCW
You do not have the required permissions to view the files attached to this post.
FLYJCW
Re: Firefly rear wheel bearings.
Postby FLYJCW » Wed Aug 24, 2016 11:01 pm
The rebuild Photos!
FLYJCW
Postby FLYJCW » Wed Aug 24, 2016 11:03 pm
So that is all four corners sorted just waiting for new brake cables from Speedy Cables!
FLYJCW
Postby FLYJCW » Wed Aug 24, 2016 11:10 pm
FLYJCW
Postby FLYJCW » Wed Aug 24, 2016 11:13 pm
A flash over with silver paint and finally here it is ready for use, technically a "slogging spanner"..... worked perfectly on the re-build!
johnlayzell
Postby johnlayzell » Thu Aug 25, 2016 1:39 pm
BRAVO! Congratulations! Turns out I have a spanner with 2 1/2" across the flats at one end, and 2 1/8" and 2 3/8" at the other. Bought it years ago at Beaulieu or similar. Can't remember when or where! W 686 is cast on the side. Never used it, but now I know what it fits!
Keep pushing!
1925 SC12/50
1937 SP25 VDP Saloon
1970 Peking to Paris Rally VW Beetle
FLYJCW
Postby FLYJCW » Thu Aug 25, 2016 7:31 pm
Thank you John for your encouragement ...... indeed amazing that you have a spanner, I couldn't find one anywhere. I got a hexagon socket for the outer plug that holds the half shaft in, from the ships chandlers in Lancaster. I bought it originally 50 years ago for Morris Minor axle end nuts but it is much smaller than the Alvis one! Regards John
Return to “Firefly and Firebird”
