1948-49 Alvis TA-14 Serial Numbers
For TA 14 and TB 14 cars
alsfarms
Postby alsfarms » Mon Jan 28, 2013 1:15 am
I have learned a bit more about serial and frame numbers. Do any of you have access to the factory information pertaining to the frame/serial number split between a 1948 and 1949 TA-14?
Alan
AAT
Re: 1948-49 Alvis TA-14 Serial Numbers
Postby AAT » Tue Jan 29, 2013 5:04 pm
If you log on to http://www.alvisarchive.com/the-fourteen you will find lots of information.
Peter Martin
Postby Peter Martin » Thu Jan 31, 2013 9:42 am
The TA14/TB14 Register published by the AOC in 1996 gives details of this stuff, ie Chassis no.,Body type,Coachbuilder,Body no.,Reg no (UK) &Despatch date.
If you post your chassis no., with luck I should be able to give you some or all of the above details.
alsfarms
Postby alsfarms » Thu Jan 31, 2013 4:11 pm
Hello Peter,
Thanks for taking the time to respond to my question on TA-14 numbers. When I get home this afternoon, I will post the frame number from both of my TA-14's. The DHC is the car I am building, the second is a donor Muliner sedan. I am anxious to learn what I can about both vehicles. I think the Muliner came to the US from Portugal. The DHC has been in the US for a long time, per past owner. Thanks again for your response.
Al
alsfarms
Postby alsfarms » Fri Feb 01, 2013 2:25 am
Hello Peter,
I was able to catch some daylight and see well enough to write down the frame numbers from both of my TA-14's. The Mulliner Sedan is #20880 and my Carbodies DHC is 22369. I hope you may be able to assist me with determining some history and pedigree for my cars.
Alan
Peter Martin
Postby Peter Martin » Fri Feb 01, 2013 8:54 am
Good Morning Alan
Hope this helps
20880, Mulliners, Saloon, Body No M33, Reg FKV619 (Coventry CBC),Despatch Date 19/02/47
22369 Carbodies, Dhc,Body No 0183/09/8, Reg GTM160 (Bedford CC),previous owner Member8652 US,Despatch date 10/11/48
I learnt to drive on my fathers Carbodies TA14 a long time ago,also failed my test 1st time. AKS880 where are you now?
Good Luck with the project
Peter
pryantcc
Postby pryantcc » Fri Feb 01, 2013 10:37 pm
alsfarms wrote:The Mulliner Sedan is #20880
I have 20889! our cars were probably in the factory at the same time :-)
alsfarms
Postby alsfarms » Sat Feb 02, 2013 4:27 am
Hello Paul,
Is youf frame number 20889 your DHC with special body?
Regards, Al
Return to “TA 14”
Users browsing this forum: No registered users and 2 guests
