Chassis and Engine numbers
For TA 14 and TB 14 cars
Postby RichardWallach » Wed May 04, 2016 11:04 am
Can a member advise whether the chassis and engine numbers are the same for this series as they are for the 3 litre cars?
pryantcc
Re: Chassis and Engine numbers
Postby pryantcc » Wed May 04, 2016 6:36 pm
RichardWallach wrote:Can a member advise whether the chassis and engine numbers are the same for this series as they are for the 3 litre cars?
Hi Richard,
What do you mean by "the same"?
The numbers obviously differ for each chassis/engine produced.
Postby RichardWallach » Wed May 04, 2016 9:56 pm
Perhaps I should have said "match", eg my 3 Litre engine and chassis share the same number.
Apologies for the confusion.
pryantcc
Postby pryantcc » Thu May 05, 2016 10:35 am
RichardWallach wrote:Perhaps I should have said "match", eg my 3 Litre engine and chassis share the same number.
Aha! I have been unable to find an engine number stamped on my engine. However, there is a plate that has a number on it. It's currently fixed to the bulkhead, maybe it was once fixed to the rocker cover? this plate has a number stamped into it that matches the number stamped on the chassis. Do you know if I can find the engine number on the block somewhere? I could check it for you.
I'm sure there are people in the know who can tell you straight out, but, unfortunately, they may never read this.
Paul.
AAT
Postby AAT » Sat May 07, 2016 9:25 am
When they were built Fourteens had the same chassis and engine number, as did the Three litre. With the passage of time many engines got changed and records have been kept which show most of these. A fine source of information on Fourteens is www.alvisfourteen.wordpress.com and Eileen Goddin maintains a database of all Fourteens.
Postby RichardWallach » Sat May 07, 2016 12:52 pm
Many thanks.
Return to “TA 14”
