Where is the oil dipstick Ta 14?
For TA 14 and TB 14 cars
Dracs
Name: Günther Schoberth-Schwingenstein
Postby Dracs » Sun Aug 06, 2017 11:07 am
Good Morning, I have bought an Alvin Ta 14 special todays ago. Now I will check all the technical parts and I´m looking for the oil dipstick. But can´t find the oil dipstick. I have the model produced 1948 with the 1890cc engine. Sorry for this questions. But how I can check the oil? Just with the oil temperature gauge?
Thx for an answer.
tf1695
Re: Where is the oil dipstick Ta 14?
Postby tf1695 » Sun Aug 06, 2017 4:45 pm
Hi Gunther,
On the carburretor side of the engine above the starter motor you will see an aluminium plate with measurements in gallons on it. There is a thin metal rod connected to a float in the oil sump which gives a reading of the oil level. Sometimes the float is punctured but you can check this by draining the oil and refilling with the correct amount of 1.5 gallons.
Good Luck,
Andrew
Dracs
Postby Dracs » Sun Aug 06, 2017 5:24 pm
Thank you very much, I will check ist out.
Postby johnlayzell » Mon Aug 07, 2017 5:17 pm
Was going to reply "if it's the same as the pre-war cars it's not a dipstick, but a float......"
Which begs the question, with which model did Alvis change to dipsticks?
Peter Martin
Postby Peter Martin » Tue Aug 08, 2017 2:30 pm
TA21 onwards ???
Return to “TA 14”
Users browsing this forum: No registered users and 2 guests
