Electronic ignition modules for TA21
For all TA 21, TB 21, TC 21 and TC 21/100 cars
Gizmologist
Postby Gizmologist » Mon Mar 21, 2016 9:21 pm
Has anyone found and fitted a positive earth electronic ignition module to a TA21? The distributor type of Lucas DVXH6A does not appear on any listed supplier I can find, although slightly later (eg TC or TD) ones seem to. I'd be happy to adapt a later one and try it, but want to find out if there is an easier solution first? I don't want to change the car's polarity, before anyone suggests that!
Thanks in advance......
Re: Electronic ignition modules for TA21
Postby DaveT » Tue Mar 22, 2016 12:34 pm
have you tried Petronix?
Please note having had two of these Petronix modules fail on my 6 cylinder Jensen 541 (+ve earth), I have gone back to standard points based ignition, so I am not making a recommendation! (We drive the 541 about 7000 to 8000 miles a year and it needs to work, be reliable and be repairable on the roadside - we are driving UK to Sicily in May which is a bit too far for the SP25).
Dave
Postby RichardWallach » Tue Mar 22, 2016 8:36 pm
Richard,
Welcome to the BB.
Get in touch with the Distributor Doctor at http://www.distributordoctor.com/
With an upgrade to electronic ignition you may like to consider replacing the rotor button. I have purchased one of their red type and can attest to the quality of the item.
Let us all know how you get on.
drdowhitt
Postby drdowhitt » Thu Mar 24, 2016 12:45 am
Hi Richard
I fitted electronic ignition to the Lucas DVXH6A on my TC21 using a kit from Jolley engineering ("classicheads.com"). It was simple to fit and works nicely with subjectively better starting and smoother running though I can't comment on longterm reliability.
Jon
Return to “TA 21, TC 21 and TC 21/100”
