"Popping" sound in the exhaust upon deceleration
For all TA 21, TB 21, TC 21 and TC 21/100 cars
Postby RichardWallach » Sat Jan 07, 2017 12:20 am
Having just converted the aging Solex to twin SU's in my TA21 I am in the process of getting the settings right. The car runs beautifully but there is a popping sound in the exhaust when coasting downhills. I presume it is related to mixture and to that end am wondering if it may be running a little lean.
I would appreciate members thoughts.
Re: "Popping" sound in the exhaust upon deceleration
Postby johnlayzell » Sat Jan 07, 2017 4:04 pm
Had the same on the Speed 25. Popping usually means fuel in the exhaust system, and in my case leaning out the 3 SUs resolved.
Good luck!
Postby Angus D'Arcy-Drake » Mon Jan 09, 2017 9:48 am
Don't be too hasty to alter things. It should pop a bit on overrun on SU's I think. I have the same issue on my TC having had it correctly tuned on a rolling road by somebody who actually knows what they are doing. I queried it at the time because it didn't happen before it was tuned. It's something to do with the vacuum created when the carb butterflies are closed as I recall.
Postby DaveT » Wed Jan 18, 2017 9:10 am
Another possibility is that you have a manifold leak - unburnt fuel in the exhaust combined with fresh oxygen via a leak (and the heat of the exhaust pipe) can cause this effect.
Dave
Postby RichardWallach » Thu Jan 19, 2017 9:51 pm
The "popping" issue has been sorted. It was Dave's suggestion that prompted me to better sort out the exhaust leak where the pipes join the manifold.
This having been done the "popping" has gone away.
Thanks for all the suggestions.
Medlbourne
Postby johnlayzell » Sun Mar 12, 2017 3:10 pm
Richard - can you expound on the "better sort out the exhaust leak where the pipes join the manifold" ?
New gaskets? Just tighten all the nuts a little? Both? Other?
After sitting for four months, the Speed 25 was similarly popping this AM, which it had not done when parked!
Thanks!
Postby RichardWallach » Sun Mar 12, 2017 9:18 pm
I have had considerable trouble trying to get a good seal between the exhaust pipes and exhaust manifold. The two surfaces are fastened by three studs with a joint washer in between. The surfaces did not mate well and a local gasket for a modern that fitted quite well would continue to blow out. The result was much unpleasant noise and exhaust popping on overrun. I had tried gasket cements etc with the same unsuccessful outcome. The physical tell tale being the continued blackened area in one particular spot between the two surfaces.
The fact that I could buy a local gasket meant that I didn't get one from RT. I checked to see if RT sold them and was surprised to see a picture of one on their website. Theirs was a thicker gasket made of copper. I subsequently purchased one. It compressed well and effectively sealed the joint. The end result is no noise and a total absence of popping. I must add that the quality of the joint washer is excellent.
I hope this helps.
Postby RichardWallach » Mon Oct 23, 2017 7:16 am
Since my last post I have replaced the single exhaust manifold with the later TC pair first sealing off the hotspot bolt holes on each manifold. This is a most worthwhile upgrade. No longer do I have gasket issues. That said the big plus is the better exhaust extraction. There is a noticeable increase in acceleration. Unfortunately part of the conversion cost was putting the car onto a tray truck in order to get it to the exhaust specialist as a new pair of front pipes is necessary.
Return to “TA 21, TC 21 and TC 21/100”
